Hey guys, about to tackle the studding of my 2005. Mileage is up there (284,000), and she's started to lose coolant on my extreme street tune. Ad to that the fact that injectors 2 and 4 suffer from terrible stiction. In addition, my oil cooler has rapidly started to plug-my deltas went from 2-4 degrees, to 10-20 degrees. Needless to say, It's time. I'll be starting this coming thursday (I have all the parts, however getting restore and restore+ in upstate NY is a challenge to say the least-it won't be here until wednesday.
Right now, I'm taking requests for specific pictures. I'll be documenting the entire process from start to finish-location of cab bolts, wiring harnesses requiring removal, and everything else I can think of.
Now on to another note:
I had a spare set of heads, and had them re-done before starting the job. It will certainly cut down on down time. They were done by UAP engine rebuilders in Utica, NY. Total cost was 494 dollars. This included:
Hot tanking the heads
magnafluxing to check for cracks
resurfacing both heads-one had .001 warpage, the other had NONE-both were well within service limits, but perfect is the name of the game
One exhaust valve needed to be replaced
all 32 valves were ground, as were the seats. They were then vacuum tested.
Also note-the above price also included the valve seal kit which was 88 bucks. Overall, I think the price was very fair, and the work looks top notch. They even removed several broken exhaust manifold bolts!
As for gaskets, I'm using victor reinz headgaskets, as well as there intake kit. Came with EVERY gasket on top of the engine-injector o-rings, oil cooler gaskets, turbo drain/feed seals and gaskets-It is the most complete set I've seen, and the price was right at 82 dollars shipped to my door.
So, in conclusion, I welcome any and all questions and/or requests. Stay tuned.
