1 - 9 of 9 Posts
How much do cab lights usually cost? Parts and labor? Would it be an easy install on an 05 F250 that did not come with them stock? Any recommendations on some cool lights?
is there a possible factory template you can use instead of measuring and running the risk of not installing properly?
Also, how is the fitment on those recons? I have read that the gasket seals do not curve properly to our roofline
I dont know of any factory templates you can get.
I just taped everything off and did some measuring, its not that hard
The fit seemed great to me
The only thing I didn't like about the kit is the cheap screws it came with. I threw them in the trash and bought some stainless steel nuts and bolts. I also put a bit of silicone on them
Do you have to buy a factory electrical harness? Or does Recon include it? So how long would you say the install took?
This is a good article on installing the lights. I have it bookmarked because I'm thinking of adding them too.
Cab light Install
I did mine, they are Recon, the kit came with a harness. it was super easy to wire up, but would have been easier yet if i had the factory harness. the lights were easy to do, just make sure you measure alot before you drill.
It comes with a harness, you just have to tap into a power source.
I think it took about 3 hours, but I had a lot of beer breaks :nod:
I really want to do this. Just do not have the time to install. Did anyone pay to have them installed? How much did they charge?
1 - 9 of 9 Posts
