1 - 5 of 5 Posts
I need some tips on putting cabs lights on a truck without them. Any help is appreated. i have an 89 or so ford out back that i'll be taking the lights off of and the wiring.
Measure everything every way possible, If one is not positioned right its really obvious. I have done 2 sets of cab lights. It helps to have 2 people to line everything up. I use tape to make out the dimensions and then drill the holes. If you want just give me a call and I can stop over and help out.
Lots of measuring and lots of masking tape. I used string and a dry erase marker to get everything layed out and then put the masking tape over it. Make sure you have tape down any where you will be drilling!
Alright Nick. I might be getting ahold of you in a couple of weeks or so. I think I'm just gonna order the kit out of LMC with the clear lights for $90.
PMR = JUNK
Sounds good let me know. (this is nick)
1 - 5 of 5 Posts
