Whats the best kit/method for deactivating the EGR and still pass the California visual smog inspection. Not that I would, just curious!
this is hat i was going to suggest.If you plug the cooler you will get an egr flow code depending on year of truck. You would need a "smog tune" from a tuner. I personally went with a bulletproof egr cooler.
Sent from my DROID2 using AutoGuide.Com Free App
umm, no... Where did you read that?Just driving in the freeze plugs have been known to come out and take out the turbo.
Happened to mine but I was lucky enough to find a dealer that took care of me under warranty.umm, no... Where did you read that?
^^^thisI have a BPD cooler with a solid uppipe and plug on back of cooler, my EGR valve is welded shut. I passed smog with ID Extreme Street installed that shuts off EGR.
For a 100% stock truck (no tuning). Keep the egr valve and egr cooler on the truck. Weld a washer on the exhaust intake of the egr cooler.Whats the best kit/method for deactivating the EGR and still pass the California visual smog inspection. Not that I would, just curious!
^^^this
I failed the first time because I had changed the tune to one with less smoke, anticipating a smoke test. They said it wasn't "ready". So I drove it around for a couple days and took it to a different, more "shady" shop. Passed in 5 min, no smoke check, no plugging into my computer hahah
From what it looked like heat melted it and went through the turbo destroying the vanes.How would a freeze plug that is properly sized and pounded into the egr cooler "take out" a turbo? If it goes anywhere it will be lodged into the egr cooler.
