Hey guys. Im considering investing in a bypass oil filter. Who makes the best product?
The only one iv seen is the FS2500. What else is out there?
I want to get one of these also, but that setup sounds like junk ^^^ I TAKE THAT BACK BECAUSE OF WHAT EARLY_99 SAID.Search on Bypass Filter on YouTube. There is a whole piece on a $60 bypass filter that sounds like the correct way to do it. Doesn't the Amsoil use a banjo bolt on the oilpan drain and a piece of rubber tube for the return line? Hang that on a rock and you would regret it.
Charlie
I forgot that the Amsoil instructions suck however the amsoil unit can mount just like every other bypass unit does. Either with a spin on adapter or into the block using existing ports that are plugged from the manufacturer.Search on Bypass Filter on YouTube. There is a whole piece on a $60 bypass filter that sounds like the correct way to do it. Doesn't the Amsoil use a banjo bolt on the oilpan drain and a piece of rubber tube for the return line? Hang that on a rock and you would regret it.
Charlie
That is totally incorrect. There is no way for the oil to flow through the system if that were the case. You can either have the adaptor that spins on where your stock filter is then your stock filter spins onto it and the lines from that adaptor or you can get the one like I've got where it has an adaptor that spins on where your stock filter goes with two fittings on it that run to a filter head that has places to mount the full flow filter along with the bypass together.Doesn't the Amsoil use a banjo bolt on the oilpan drain and a piece of rubber tube for the return line? Hang that on a rock and you would regret it.
Charlie
