Looking at buying a set of used arp headstuds for my 6.0, what should i look for? Any things i should be aware of? Will so eone install used headstuds on my truck, or do diesel shops only install new ones?
Have you ever used a used condom???Looking at buying a set of used arp headstuds for my 6.0, what should i look for? Any things i should be aware of? Will so eone install used headstuds on my truck, or do diesel shops only install new ones?
Not true if they are torqued to proper specs. Used studs are fine so long as they were installed properly the first time around. I have used studs in my truck and haven't had a singe issue from them.If you rely on the truck day after day, i would definitely just grab some new ones. After the studs have been torqued down they stretch, and evidently would be weaker. My :twocents:
$250, on a truck about a 1000 miles, then the left side head crackedhow cheap are they?
Might just do itChit dude buy them.
