I need to take the front bumper off my 03 to reinstall my fog lights. One of the mounting plates was broken in a hit and run with a deer. Now I need to reinstall it and it looks like the only way is to take the bumper off. Where are all the bolts located on the bumper? Is this going to be an all day process? Thanks.
N-
10 minutes tops. Take the four bolts out located next to the tow hooks, and the bolt on each side in the fender well that holds the bracket to the frame. Be sure to disconnect the fogs, and remove the clips for the harness, and the block heater plug before you unbolt it.
Thanks Justin!!
