1 - 5 of 5 Posts
· Registered
Anybody use this? Im considering buying one because I just need a monitor without adding perforance like the edge unit does. Because I would be stacking this with a banks bullet module. Thoughts?
· Another 6Slow
They make the edge insight cts that is for monitoring, I have no experience with the bullydog though. Also if I were u I would sell the banks and buy the sct x3 so u can have your truck cutstom tuned
· Registered
I second that... CTS plus SCT w/custom tunz is the ONLY way to go. BTW Matt's SRL will destroy anything the Bullydog will put out IMHO.
· Registered
That's great... but the watchdog w/egt is around $389 out the door from Jegs, the CTS with egt probe is closer to $500. I'm not made of money (as i suspect many of us aren't) and if it tells me the info I want to know I could care less who makes it.
With that being said, anybody used it and does it work? I haven't seen many reviews on the interwebs.
· Premium Member
cant really tell you much about the BD because i have never used it nor i know anyone with it.. the fact that their are not a whole lot of people using should tell you something
you could always go with the insight CS.. its smaller than the CTS but you will still be able to monitor everything the CTS does and its 100 bucks cheaper... like this: Edge Inisight CS
1 - 5 of 5 Posts
