1 - 8 of 8 Posts
OperationSmile.org
So I did my shackle lift and I am sitting 2 inches shy of being level. I am running 315/75 r 16.5. I am still rubbing on the rear of the fender well. So now I am considering building my own hanger brackets. I am hoping for another 2.5 to 3 inches out of this. So I need some help. With my 2.5 inch shackels what can I see total lift wise? I am planning on lowering the bolt 3 inches down and 1 inch forward from the factory bolt location. I am sure I will have to get a adjustable track bar bracket and new shocks. Does anybody see any issues I may see or see anything I am missing?
I don't.... Let me know how it goes???
My first .02 in this thread is get rid of the suicide wheel. 16.5 rims have no tire seat in them. If you have low pressure and take a curve to fast you will lose the tire... go to a 17 or drop to a 16... Very good advice...as for what you are trying to do with shackles, just give superlift a call, they have a lift leaf spring that should work and give you enough clearance up front either that or I think you may be able to add-a-leaf into the leaf pack. I don't know that for sure though.
Ask Scuffy828 about his. He builds them, there only 50 bux, and he said he wouldnt go higher then 2.5" cause if the pinion angle of the driveshaft. see what his input is. Hes the guru about that stuff
OperationSmile.org
The reason I am asking is because the 3.5 in hanger lift I was looking at had shackles just like mine with it. I am trying to keep as goood of a ride quality as possible. Adding a leaf would stiffen my ride I would think. But I will look into your advise DunesRUnner. BTW where at in phoenix are you?
what hangars did you install on the front to begin with????
I live 43rd Ave and union hills and work Roosevelt and 24th st...why u ask?
OperationSmile.org
Discussion Starter · #8 ·
They are stock hangers on there right now. I put shackles on it though.
DunesRunner- I grew up at 35th ave and greenway and my wife grew up around your area. We are moving back in August
1 - 8 of 8 Posts
