81 - 85 of 85 Posts
Garage has been cleaned haha. We had just broken down a very large tent from a block party we had. Yeah, it was a mess for a while.
hey there new guy here about to order my stuff for my retro ive seen people with 6.7s use both of these kits and i have heard nothing but good things about both. only difference is retro-solutions offers a lifetime warranty on there hid kits so ill likely be going that route .
The Retrofit Source Inc
https://retro-solutions.net/cart.php?timestamp=1418739466
so for the install with the newer style "easy fit" projectors
all you have to do back the truck up from the wall 25 feet mark where the oem light cut off is on the wall using masking tape, grind the back oem h13 housing part down to allow the nut from the projector to stick out use the supplied washer to sink it in and align itself ,wire them up using supplied the supplied h13 adapter harness, line them up according to the oem cut off marked as best as possible. and thats it?
ill also say i have painted a few sets with some friends so getting them apart isnt hard for me.. just want to make sure i am fully understanding the process here before placing a order if i have missed any steps please add to it!..
I know this thread is a week or so old but it sounds like you pretty much have it figured out. The only thing I'm unsure of is when you sand the base down I think you will also be sanding away the location that the alignment washer will set in so you will have to manually align them. Still should be easy. I almost went with the Mini H1 6.0 kit but ended up with the D2S 3.0 square lens for my install. My parts should be here tomorrow and I hope to get them done this weekend.
I put my order in for the D2S 3.0 retrofit kit. I do not think I will be doing any painting. I had paint matched retrofits in my previous truck and did not think they made that much of a difference (I can't see the paint while driving anyway.)
The only part I am concerned about is splitting the headlights!
Also, I ordered the Denso ballasts with the idea that I can continue to use the auto on/off lights. With the morimoto ballasts, it had to be manual and I did not like that at all.
81 - 85 of 85 Posts
