1 - 2 of 2 Posts
Bought 8 new glow plugs from ford and they are the same ones that are in the truck did ford update glow plugs and keep same part number?
If your asking the question do to the “busted tip” of the glow plugs in the early production 6.7s that’s not the cause of the problem. The valves were the issues they just so happen to bust the tip of the glow plug off and that’s the first site mechanics see when they go into the shop is they pull the glow plug and it’s busted off but that’s only caused to poor quality valves which were changed, since you already bought them I would put them in and move on. But if you were trying to swap them out to remedy the “fix” that wasn’t the problem
Reactions: Larry1013
1 - 2 of 2 Posts
