1 - 12 of 12 Posts
Company truck is a 06 F550 with a 4.88 rear end. I am getting around 8mpg at the moment, wondering if there are any cheap mods out there to be done. Someone told me to remove the "power scrubber"/ catalytic converter I guess.
Thanks in advance,
Danny
Did the ******* version already......
took the trusty dremel tool with a cutting blade and slotted the whole panel in front of the air filter. Thanks for looking though.
Different tire/wheel size to compensate the wicked gearing... :dunno:
You could always run the N-O-A-C mod. I frequently run that modification. I see about a 1 mpg difference.
not too cheap but a definate fix without having to change gears would be a gear vendors o/d . It would pay for itself in a year and no ill effects on towing ability. You never mentioned if you are towing and if your towing loads close to gvrw with that mpg.
Discussion Starter · #12 ·
Truck weighs 10K and I regularly haul 8K on the bed. I normally haul two batteries for electric lift trucks that can weigh upto 4K each. I average around 8 mpg empty.
1 - 12 of 12 Posts
