1 - 9 of 9 Posts
· Registered
What's a good budget hoop that is good for stage 1s? The cheaper one I found so far is the t500 for $450 through riff raff. Any suggestions?
· Registered
But will a used SD pump work fine on the stage 1s or as good as the t500?
· Registered
Any cheaper options or should I skip it with stage 1s
· Full A-Team Member
Your truck will run fine with the 15* hpop thats in it, but you wont be getting everyhting out of those awesome new injectors. Unless you can find a used T500, the new T500 is the cheapest option
· Delivers Pizzas For Fun!
Id go with a 17* if u can find a known good one, if not t500.. anything larger then stage 1s, go t500 (well till u get to the big stuff)
1 - 9 of 9 Posts
