Hi everyone!
My 05 F350 w the 6.0 started smoking a little the other day. By the time I got close to home (about 35 miles) the smoke had turned from black to plumes of white and had thrown code p0284. Figured I had broken an injector tip. Ordered 4 OE injectors and replaced all on drivers side. Sure enough #8 tip was broken off and mangled end of glow plug. Got it all switched out and fired her up. Still getting p0284 and now p0300. A little bit of white smoke but not a lot. Seems to be running a little rough. Couple of questions if anyone can help me out:
1. Do I need to worry about the broken off piece or is it likely gone by now?
2. Not a lot of info on the p0300 random misfire code. Thoughts on this with p0284?
3. Any other advice on where to go from here?
Thanks so much! Appreciate any help!
768472
768473
BoreScope - check for piston/valve/cylinder damage
