So late last night I started smelling diesel from under the truck. I got home and looked underneath while the truck was running and my hose from the airdog 2 to my factory fuel line to the motor was leaking extremely bad from the fitting. I pulled the pump out and replaced the o-ring but its still leaking bad. It looked as if the pump shift against the transfer case and bent the jiffy connector. Does anyone know if just a hose and fitting can be purchased or does anyone have other suggestions? I thought about cutting the fitting off of the hose and recrimping it with a different fitting and then putting the same style fitting on the pump but was told that the hose cant be crimped by a local hydraulic shop. I am desperate for a suggestion to get the truck running as I need to get back to work ASAP
