1 - 12 of 12 Posts
I installed my guages tonite and my boost is not working. I'm not convenced that the gauge isn't bad yet. But just to check where is the best place to splice in for the boost?
Addicted to Diesel
ok when checking the boost did you drive it or just sitting in park push the pedal down? cause i didnt get much reading just sitting in park and pressing the pedal.
drove it. And got on it
Addicted to Diesel
hmm.. i truly dont know the best splice place for the OBS. until someone else comes along all i can say is recheck the connections and make sure everything is tight. sorry your having trouble with it
I spliced into the MAP line for my boost gauge. Also to check your gauge you could take an air hose and turn the air pressure down and then blow some air into your boost line to see if it moves the gauge.
a truck
yeah defnitely splice into the MAP sensor line, and mine wasn't working for a while either until I found a kink in the line going to the boost guage, so I would splice into that and check the hose for any kinks
Discussion Starter · #7 ·
Ok call me stupid . lol But where exactly is the line I need to splice into at? draw me a picture. lol There is a line that I wanted to splice into but I will need more hose to get to it, And keep the line safe. Any help would be greatly appreciated. Thanks giuys
a truck
Its a smaller silicone hose that runs from just under the turbo to the map sensor mounted on the passenger side of the firewall. Its a small diameter hose that kind of stands alone. Ill see if I can find a photo, I only knew which one it was becuase my gauge came with a picture illustrating where the map sensor line was
Here check out this link. I think it will help you. Gauge Install
Discussion Starter · #10 ·
Ok I got it hooked up right, and it's working now. Thanks
No problem. Have fun!
Addicted to Diesel
glad you got it all figured out
1 - 12 of 12 Posts
