1 - 7 of 7 Posts
i was checking everything today and noticed this wire i never had seen before. it comes off the green MAP sensor wire and goes to ground. i remember reading something about it but i cant find what it was.
interesting, did you install it a while back and not remember what its for?
nope bought the truck with it alittle over a year ago.
John Wood Nut Swinger
That is an Old school zener diode boost fooler. It is all part of the banks kit on your truck.
Froggie loves the idea, I don't. I noticed a decent amount of low end power gain when I went to a blow off type of fooler. Now I run a regulator style from ITP and it is by far the best one I have run.
Discussion Starter · #5 · (Edited)
ok thanks :thumb:
since it works fine and i top out at 22psi boost is there anything to gain from switching to an ITP fooler?
strokin early99- got 2 quick questions, are you running a holley fuel pump? and how are your traction bars doing?
thanks
The pump I am running is a Walbro GSL392.
My traction bars made my truck launch so much harder and better on the drag strip and for the first time ever, I had no wheel hop on the sled pulling track.
Discussion Starter · #7 ·
i wonder if that pump is the same as the one holley sells, looks identical to the one on my sandrail.
thanks
1 - 7 of 7 Posts
