Well I searched a little and could not find what I am looking for.
I see very little boost cruising at about 50-60 mph, is that normal? Its maybe showing 1psi on the gauge, maybe less. THis is on a flat road just steady throttle. At 70mph I see about 5psi.
What are your numbers like? THanks.
Lifetime Premium Member
That sounds about right.
Ya that sounds right. If there is no strain on the motor, and your foot is barely on the gas.. it doesnt matter HOW fast your going you aren't going to see boost (well, until you start reaching aerodynamic limiting, in which case you'll start seeing boost rise to compensate for it being tougher to move in the forward direction).
And as you said at 70mph it's starting to strain a bit, so it's slightly tapping into boost to maintain forward momentum at the given speed. I bet if you push the pedal down it will nearly instantly start boosting.
