1 - 7 of 7 Posts
So I have my truck booked in for monday to do the upper / lower ball joints on both sides. While it's getting tore apart, I'm getting them to replace the o-rings and seals for the hubs.
Anything else I should be doing?
I thought of doing the leveling kit, but ran out of time to order it.:(
Brakes were just done about 10,000 kms ago......so they should be good.
They quoted me $1200.00 including alignment.:dunno:
that sounds about right i was quoted 950 to do mine. make sure they use teh moog brand ball joints so you can grease them. and from whati know there is 2 orings that need to be replaced or at least looked at while everything is off. one of them is teh culprit for the auto hubs not working
Right on......
He is changing 4 seals and 2 o-rings.:thumb:
I don't know if that is right or not, but he agreed that the seals and o-rings should be done.
The seals seem really expensive, but he said he gets them from Ford.
Seals were about 118 and 80. $200.00 just for the seals!
I wish I could've done the leveling kit at the same time considering I'll need an alignment......again!
The entire kit of 4 ball joints, and seals is only $263 from powerstrokeshop.com. An alignment is about $80. So you're paying $857 in labor...labor that will take about 3 hours. Damn do they lube you for that? I suggest you get some experience and do it yourself or with the help of someone on here if there's someone local to you.
No Kidding!!! I feel ripped off now. The last set I did I only charged the guy 300. and that included replacing the axle u-joints too :doh: But he did have to take it somewhere to get the alignment done. No wonder he was so happy.
I agree to high. Mechanic buy trade did my own 3 hours tops. Dont no what book time is maybe 6 hours. I fix Toyotas.
my boss and i did mine on my old stroke 4x4 and it took us about 3 hours tops. wasnt very hard at all.
1 - 7 of 7 Posts
