Hello. Looking for information about the install of the blue spring mod. I have a 2006 F250 6.0l with 102k on it. Any information with pics would be appreciated. Problem areas to look for. If there are different part numbers for different years. Have heard of some issues with install and extra parts left over. Where is the best pricing on purchasing them also. Thanks-Shane
Here is a good set of photos:
Fuel Regulator Upgrade w/ Pictures - Diesel Forum - TheDieselStop.com
Be careful with the fuel lines when you start to disconnect them!!!!!
Here is a place to get the kit. You really do not need a new cover.
Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit
I don't remember which years don't use all the parts. You will be able to tell when you get in there.
Careful, that spring inside has quite a force on it, so keep pressure on the cover when you undo the last bolt.
I'd probably use the search function. It has been covered multiple times with lots of other photos and little helpful hints.
