Ok, so I've known I've had a blown head gasket for a while now. I've got money saved up and am going to do gaskets and studs soon. For a long time it has puked coolant, cap went bad, heater control valve has failed twice, so it's putting excess pressure into the cooling system and just breaks the next weakest link. Lately it's developed a much worse leak but I haven't been able to find it yet, it drips right on the front pumpkin but I can't see from where.
And this morning, I happened to be standing outside of it when I remote started it and saw some smoke, not water, I'm thinking oil, it was kind of dark grey/blue. It's never had even the slightest puff of smoke before. I've seen water smoke come out of another truck that had a blown EGR cooler, it was white. I did the EGR delete and oil cooler replacement, full system flush and swap to ELC-1 coolant last winter. I checked it again after work, did the remote start from outside and no smoke, so it seems to be overnight after it sits maybe?
Lately I've noticed that my oil temps are running high if I drive very far, like coolant temps in the 180's and oil temps up to 210-215 on a long drive running 70-80mph. I've checked and the oil is full. Wondering if it had something to do with the headgaskets or maybe the new oil cooler finally picked up the rest of the leftover old coolant and clogged? It's never leaked or burned a drop of oil since I've had it for almost 2 years. It's an '05 with almost 150k miles.
