Looking for advice . . . . I'm not a gearhead but I'm a good listener.
I'm on my 3rd PSD truck and always had good luck till now.
I got a 2002 7.3 Crew Cab 2 WD 8' bed with 175,000 miles. I was 110 miles into a 3,000 trip when I developed a skip in the engine. I had just gotten fuel so I thought it was bad fuel. While trying to get to a dealer I developed a lot of blow by. Got to a Lincoln/Mer dealer who deals with Ford trucks. They check the codes and said something was wrong with the left bank. They did a compression check and discover zero compress in cylinder 2 or 4 and 50% compression in the other cylinder. They guessed it was either a hole or a crack piston in the one cylinder and maybe some bad rings in the other cylinder. They tested the fuel and said it was OK. They said the best thing to do is buy a long block for about $9000 and about $2000 to install. I said the truck is only worth about $13,000. So I had the truck towed home it still runs but is low on power and smokes a lot.
Yes I did the air intake, the Super Chip and Exhaust, I ran it only on the middle program (adds 70 hp) and it was the best 170,000 miles I ever had in a truck, it would really haul my 40 ft trailers. Other than the engine this truck is in great shape. I just had the whole front end redone for $1200 the truck felt better than new.
My question is what would you guys do. I only need a truck for another 6 months to sell off my camper and 2 car trailers and I got to move myself from CT to MA.
Thank you in advance for any helpful advice.
Cousin Vinnie
Cousin Vinnie
