1 - 1 of 1 Posts
I am new to the forum have been reading a lot of the post my truck has been pretty good the turbo was replaced under warranty when i had a check engine on they said they did not know what it was so they replaced it. Egr was replaced when the truck was only a year or two old check engine on again they said they were not sure what it was. The injector module (ficm?) was replaced under warranty also just before the warranty ran out 100,000. It started not starting right off when it was cold then i had a little skip in it put ford cleaner in it and it ran better and smoother but smokes if i lay into it. I need the switch coolant I have the gold in it i saw a post from someone that flushed at 145000 and is using john deere coolant without changing the oil cooler without any problems. I am looking at the auto enginuity scan tool st06-usb?
06 f250 120000mi well mantained but i have not done anything about the problems. Wish I could have my 96 7.3 back what a great truck that was.
Thanks Jeff
1 - 1 of 1 Posts
