1 - 11 of 11 Posts
Looking into upgrades on my '02 PSD.
Right now I have a S&D intake and straight piped exhaust. I will eventually be getting some Stage 1 injectors from Beans, modified IDM, and a DP tuner to go with it.
What turbo upgrades are best for me?
My truck is my daily driver (about 75 - 100 miles a day), I tow fairly often (8-10k) and I use my truck a lot for work around the house.
Thanks.
Edit: I do most of my parts buying from either Beans or DieselSite, for no other reason than that's where I got all the performance parts for my '97 from.
I am with CT, he sold me my 38r and stage one injectors. I love my combo whether it is for towing or all around daily driving. You will get awesome egt's from that 38r.
Is that the best match for me?
What about all those upgrades they sell for the stock turbo?
I don't know much about them, so I'm just curious.
Ported housing or wicked wheel don't do anything for performance compared to a 38r. if you are upgrading injectors i would definitely go with the 38r.
or a beans SD 66 is about the same i think, just not a ball bearing. which makes it a little quieter and easier to rebuild. Just another option. i dont think you can go wrong with a 38r either.
daily driving and 8-10k towing.. you can do a LOT with the stock turbo if thats all you need (unless you have a set hp/tq in mind).
No set hp/tq numbers; I just want to do the few upgrades I listed to better the truck:
5" exhaust, cold air intake, stage ones, modified IDM, DP tuner, valve body, 6.0 tranny cooler, if for whatever reason my hpop goes bad I'll upgrade to a modded one.
I want a turbo that will match my setup & driving style the best.
If you do an idm make sure its the swamps unit. the stock turbo will be just fine with that setup.
So if I stick with the stock turbo; of all the upgrades I've seen on vendors websites, which ones should I be concentrating on?
the list you posted looks perfect for towing/daily driving.
1 - 11 of 11 Posts
