1 - 20 of 31 Posts
My girl is very sensitive to motion and gets motion sickness easily. The first time we went out in the camper she was not very happy. every time I moved the whole thing would rock and she was miserable. I tried the king pin tripod and that did little to help. I started looking for ways to make it more solid. I found a few places that made good kits, JT strong arms, plugitrite and BAL. All were expensive and I am a DIYer kind of guy. So I first tested my theory with some shelve bars I had sitting at work. Worked AWESOME! So off to tractor supply I went to get some angle iron and some C clamps. (lowes or home depot would work too) A total cost of about $42 bucks and now my 5er is very solid! O and you must use angle iron and not flat stock. The bars were about $13 each and the clamps were $4 each. Takes about 1 to 2 minutes to install and less to remove.
I might add a bar on the back scissor jacks at some point. Maybe maybe not, its pretty solid like this. I use the el cheap o plastic chocks
looks sturdy now !!!
I have scissors on the back and power jacks on the front. I thought about adding a few jacks on the frame in the middle but those jacks are expensive!
there are bars kits for the back also that make an x on the scissors but Mine are dropped about 8 inches because of the hitch on the back. this keeps them pretty wide and very stable.
Glad you found something that works. Clean it up, patent it and make a fortune!
My son (8 or 9 at the time) woke up one night and yelled across the camper "DAD THE CAMPER IS MOVING!!!". My wife and I quit what we were doing.:doh: We can't wait until the kids get their own camper and we can shake ours again.:dunno:
LOL!!!
I've seen those on other 5th wheels around. Might look into getting something like that myself!!
Land Yatch Driver
That is some funny s**t!!!:hehe::hehe:
:rofl::hehe::rofl::hehe::rofl:
Go to the wrecking yards and pick up jacks form them , about $10.00 a piece and weikd them up anywhere you want, Good luck
Powerstroke Junkie
I wish I could find a salvage yard around me that had RV's so I could get another set of jacks for mine. The best thing I have found is good wheel chocks, the BAL ones work the best, I also take a little weight off the tongue jack which helps, but I would still like to add another set of jack stands. If anyone has a salvage yard close to them that sells RV's and want to help me out I would appreciate it.
Thanks'
NCH
Most cars use the scissor type jack for emergency tire changes. Just get a couple of them and weld them on.
Discussion Starter #16
I also added a brace to the back jacks and that helps even more!
:hehe::hehe::hehe:
There is a company that makes something similar....
Welcome to JT's RV Accessories - Haven't used them myself, but I see them pop up a lot on the Trailer Life Directory Forums.
I bought this for the back of my 5th wheel - Works very well.
http://www.waynesrvstabilizer.com/
I also have a King Pin tri-pod, but don't use it every time.
Discussion Starter #19
Yep and they are about $350 for the JTs and $250 for the plugitright setup. My X cost me about $70 with the front and single back.
I will probably get the plugitright setup some day. I just needed something fast and cheap right away. If the 5er rocks too much my girl gets sick and no camping for me.
kool mod, i'll pass, just one more thing to add to my setup time which cuts into the fun time. I don't care if it moves though.
1 - 20 of 31 Posts
