1 - 15 of 15 Posts
Best Resonably Priced Water/Methanol Injection Kit
I have read a bit on the topic and now I am interested. I have to ask you seasoned tuners, is methanol injection a modification worth seriously considering for our OBS PSDs?
I see these kits can be fairly inexpensive, bump hp, lower EGTS and can be operated via an adjustable pressure switch. I like the idea but when I start to research which kit would be best for one of our trucks I get a bit confused by shear number of options available.
Is there a particular methanol injection kit that you would recommend for our trucks?
Snow performances kit i like it:thumb:
i got a AIS kit 400 shipped to my door its simple and works
How hard was it to install and about how much performance did you get? And how often do you have to fill it up?
Thanks guys, can someone link up what they consider a good deal on a kit they like? Snows makes a bunch of kits, but I am not sure which one to get and AIS is a brand I have never heard of at this point.
I have been doing some research on AIS. definetly best bang for the buck. high quality pump and the whole kit looks very professional. looks around $350 with the big tank.
Discussion Starter #7 (Edited)
AIS is out of columbus ohio i believe, its a simpple affortable kit nothing fancy, really good customer service when i had questions with intalling slight performance, it would effectivly drop egts 200 degrees well not proven but with test on my own its what i came up with
Does the water tank fit under the hood?
If so, where did you mount it?
I must say, it does look like a nice clean kit.
Move your batteries and mount it there
Discussion Starter #11
I have two batteries, which one is preferable to move?
Also, where then does one reloacate the battery that I had to move for installation of the water tank?
Does someone have a picture of the kit installed under the hood?
I'm saying move both I saw a guy who drag raced his a while back put 2 optima red tops in a small metal frame and had that mounted to the frame rail under the truck. Looked sweet, and his water meth kit was inbthe bed tho.
I have mine mounted on the frame below the bed with a "trap door" cut into the bed. This way it stays cool under the bed and its not a ***** to fill and it stays out of the way
Got piks? That sounds like a pretty sweet spot, got a skid plate on it or anything to protect from debris?
1 - 15 of 15 Posts
