1 - 20 of 22 Posts
· Registered
wondering what the best oil is for my 6.4?? is royal purple good?
thnaks for the help:icon_ford:
· Registered
Royal purple is good but not cheap. Are you looking to go with synthetic or standard dino? When it comes to oil most on here are going to say amsoil, rotella, and valvoline blue, or mobile. Synthetic oil I feel is a waste of money in these trucks. It is worth the money if you are going to extend your oil change intervals, but that is not wise because ford will void your warranty in a heartbeat if you have issues and cant prove oil changes at least every 5k miles. I run synthetic in my truck in the winter in my truck to help with extreme cold starts but still change it every 5k miles.
· Registered
thanks
i live in texas and drive mostly city and race. what would you reccomend?? and is royal purple good or bad?
· Dont Mess With Texas!
i run rotella...that is what my local ford dealer keeps on the shelf besides all the motorcraft ****, and i love it so far
· Registered
Royal purple is good oil, but there are better options out there for diesel oil. If I were you I would run a good dino such as rotella, or valvoline blue and call it good. Look at the price difference between synthetic and dino and you will realize with out extending your change intervals that you can pocket an extra $50-60 every oil change.
· Registered
If you've ever changed your oil on your diesel truck (I've been changing my own for the past 40 years), you'll notice that the used oil has a lot more contaminates (why else would it be so black?) in it than what comes out of a typical gasoline engine.
I know that synthetic oils don't break-down like regular oils, but they still get dirty from engine deposits and those deposits aren't removed from your engine until they run through the filter, so on the way to the filter the deposits can do damage.
I say:
Forget Royal Purple or any other synthetic unless you're going to change the oil at 5,000 mile intervals or less, if you are going to be doing a lot of Racing.
Stay with a good quality conventional oil (Shell Rotella, Chevron Delo 400, or Motorcraft) and change it every 3,000 to 4,000 miles and you'll never have a problem.
Oh yeah, if you're on a road-trip and by chance need oil, don't plan on finding Royal Purple or many of the other synthetics just anywhere. You can always find Rotella.
The following information has been offered as "an opinion" and should not be construed as "bashing" or "promoting" any oil.
Be leery of those on the forum selling Snake oil.
· Registered
Where i work we punish our trucks and the company i work for has around 100 hundred ford diesels 00-10 model years we have no paved roads just beat up gravel roads and we run these trucks 24-7 365 and we run nothing but chevron delo nothing has held up as good and we have tested alot of oils. In my personal trucks its all i run after seeing what it holds up to at my work seriously impressed me. I can't speak for synthetics I have ran synthetics in heavy equipment because it had alot of down time in extreme cold temps and it was nice to have in those situations the equipment needed to run and there was no chance for a service for a long period. Its all personal preference in the end everyone has different opinions on the subject.
· Don't you worry about it
2017 F250
Motorcraft for me, nothing wrong with rotella. I did try the T6 synth rotella and got a horrible blackstone report and when I switched back to motorcraft the result was back to normal.
· Registered
My dealer puts in regular rotella for me and i do it every 4 thousand. Did it on my 08 and my 10. Never had any oil related problems!
· Registered
Can you elaborate on the results you two got with the T6 syn? Ive got about 8000km so far on mine with the T6. (I am tuned and dpf deleted)
2017 F250
mine had excessive fuel in oil causing high metal contents. Iron and aluminum I think. You don't have to worry about that because you had enough money to do the delete. ;-)
· Registered
Ah ok, I was wondering if it had anything to do with regen.
· Premium Member
Valvoline 5w40 Extreme Blue. I have used Motorcraft, Rotella 5w40 full synthetic, and the Valvoline full synthetic. My truck runs best with the Valvoline full synthetic.
· Premium Member
Can you elaborate?
I have used Valvoline in all of my cars for years but have been leery of using in my diesels. I guess I'm "brainwashed" on using Rotella.
Thanks!
Something about the way my truck smells on Rotella I didn't like. I have also heard things about Rotella that I didn't like. You have to take things you hear with a grain of salt though, so that isn't my main reason. Going by the smell difference, my truck seems be "cleaner" on the Valvoline oil.
Oil is personal preference for most. I have had great success with Valvoline over the past 109,000 miles, so that is what I use and will stick with. :thumb:
· Registered
I've always used Rotella but heard something about better mileage with syn. oil. I wonder if the savings would be worth it?
· Premium Member
As long it has the CJ-4 rating and you change your oil often any good quality oil will do although synthetic oil performs better.
· Premium Member
Good point. Running synthetic and changing at 5000 to 6000 mile intervals is not worth the extra expense for maybe a small mileage increase.
1 - 20 of 22 Posts
