1 - 20 of 23 Posts
I am looking for a set of the best gauges in anyones opinion. Boost Egt Tranny temp. I'd like to buy cheaper ones but also reliable.
I've always ran autometer. Don't know about the others.
Have autometer. Matches OEM very well.
What series do you recommend?
autometer boost, pyro, trans and fuel, then a scanguage 2 for the rest
I think mine are the ultra-lite series, they look slick with gray interior.
I recommend auto meter or ISSPRO. Both are awesome. Stay away from Sunpro, Faze and other brands like that.
That's the general concensus, AutoMeter or Isspro.
Most people go with the three pod setup. I went with the four, just because I wanted more. But it is a tight fit with the dash. Four is fine if you are going to put it in and hardly ever take it out, which you shouldn't need to do anyway.
The Silent Service
I run the Autometer GS series, and have painted the chrome rings on them. Almost a perfect match to OEM that way.
I run single pod under the grab handle for EGT, and the rest in sig in a quad pod over the rear view mirror. Everything else I monitor via an Edge Insight.
You gotta pic of that quad pod?
The Silent Service
Give me a sec here, Ryan. I'll try and find it.
Negative, I have a couple of pics of the install, but none of the finished product. I need to get the write up finished and take a couple more photos.
Sounds good.
back to business
I run Isspro EV2's, couldn't be happier.
Quad pod w/ trans temp, EGT, Fuel Press and Coolant temp
Was it a pain to get that pod in? Or out if you had to?
back to business
In was fine, haven't had a need to ever take it out. But that wouldn't be too hard, it would just leave a couple of holes in the stock A pillar, and an empty spot where the stock grab handle should be.
Getting mine in was ridiculous. Of course I didn't take the dash out. It's just a really tight fit.
1 - 20 of 23 Posts
