1 - 20 of 26 Posts
First off I'm Zach kinda new here. I am stationed in Germany with my 06 F-250. Recently I had to go back the the stock tune since I was pushing coolant out of the degas bottle. Since I have changed back i have noticed no leaking really but ITS TOO SLOW. I would like to wait until I get back to the states in Dec to do the studs but I don't want to damage my motor? So my question is which kit is TRULY complete? I called BPD about there kit and it seems complete but i just wanted to check here first. If I get it torn down and i'm missing something its a 10 day wait for the part to get here.
I plan on just buying Heads from Odessa before i even start.
Mods currently- EGR Delete, Updated fuel spring, dummy plugs, stand pipes, turbo drain, STC fitting, 58v BPD FICM, Edge CTS for monitoring and Fuel PSI, EGT, Coolant PSI and Volts.
Stay away from Odessa! Few horror storied on here about them.
Reactions: Bu2je
Ok I just did a search and I will NOT be using Odessa heads. I thought after reading Bryan's (Tuscany) thread they would be a good option but apparently not. Now I just have to find out where to get my heads from.
Yes there is a member here, Onebadcoastie, who had a heck of a time dealing with them. A few others as well. I would look at OEM. I wouldn't buy a "kit" you can save a good amount of money sourcing the parts out through various venders.
Head Stud parts list:
Arp studs
Factory 18mm gaskets
Injector O rings( Or do these come with new injectors)
Turbo install kit
Exhaust manifold gaskets
New water pump ( Gasket?)
New idler pully
Updated Turbo supply line
(Already have updated: Blue spring, STC, turbo drain, Dummy plugs, Stand pipes and installed an oil cooler about 4 months ago)
Anything else to add to my list? remember I have to order EVERYTHING and it takes 10 days to get here!
Hey Zach, Thanks for your service!
I have the same issue, puking degas mainly in extreme street tune. I have also returned to stock until I pressure test the coolant system to ensure I have HG failure...
Good luck on the list and final stages of bulletproofing!!
You think he'll still save money paying international shipping on each individual order? Not trying to be a pain, because i'm sourcing individually as well, but international shipping gets expensive. Just something to think about.
Hmm..good call didn't consider the international thing.
No worries there! Im on a military post so I ship everything through USPS Priority flat rate. I just try to order everything from the same dealer or 2.
Glow plug harness would be wise IMO (4C2Z-12A690-AB and 5C3Z-12A690-A)
Also
Two Rocker carrier box gaskets (3C3Z-6584-AA)
One Intake gasket kit (3C3Z-9433-BJ) - contains turbo gaskets also IIRC
Discussion Starter #11 (Edited)
Current list What would you add?
Arp studs *
Factory 18mm gaskets x2*
Injector O rings( Or do these come with new injector) x8 *
Turbo install kit*
Exhaust manifold gaskets x2*
New water pump
New idler pully
Updated Turbo supply line*
Down pipe clamp*
Up pipe clamp*
Glow plugs x8*
Turbo rebuild kit*
This is about $2,800
When I did my over haul job I had no clue as to what I needed. After doing a ton of research Bullet Proof seemed to be the way to go. I just couldn't find any bad reviews of their stuff. I called them up and told them what I was looking to do and they were awesome. The instruction's that come with the parts are unbelievable. Well put it this way, I kept them after the job was over. Just didn't seem right to throw them away.
I went with the external oil cooler with cold weather kit. The oil bypass filter with the amsoil upgrade. The upgraded egr cooler. A BPD water pump along with their all aluminum radiator and also got the professional install kit. While I had it all apart I changed out the little things like T-stat,hoses ,serp belt etc. The one thing I over looked and should of swapped out while I had it all apart was the serp belt tensioner.
Also
Bismic man, you fudged that second Glow plug harness number. Should be a 4C2Z-12690-AB and a 4C2Z-12A690-BA.
Here's what I have on my list to do while mine is apart.
3C3Z-9229-AA Injector O-Ring Kit x8
4C3Z-12A342-AA ZD-13 Glow Plug x8
4C2Z-12A690-AB Glow Plug Wire Asy x1
4C2Z-12A690-BA Glow Plug Wire Asy x1
W302908 Dummy Plugs x2
3C3Z-9T514-AG Turbo Hardware/O-Ring Kit x1
3C3Z-6584-AA Rocker Box Gasket x2
W302352 Up Pipe Bolt x4
W300051 Up Pipe Nut x4
3C3Z-6A642-CA Oil Cooler Kit x1
3C3Z-9439-AA Intake Gasket x2
6C3Z-6051-AA Head Gasket Kit x2 (Contains 1 gasket, bolts, standpipes and dowel pins) x2
6E7Z-9C165-B Blue Spring W/O Cover x1
6E7Z-9C082-A Updated HFCM Drain Plug x1
4C4Z-8575-AA Thermostat x1
4C3Z-9B246-F STC Fitting Update Kit x1
New Turbo boots from Riff Raff
New T-Bolt spring clamps from Dieselsite
ARP studs
Sinister coolant filter
IPR EGR delete
ELC Coolant
If I listed anything you already have (which I know I did) Just disregard it. Not all of this is necessary, its just easier to do it all while you're in there than it is to do later. I didn't list the oil, trans filters,fuel filters, air filter, or any of the fluids required for those, because I assumed you already keep up on that, and this truck is new to me so I am doing them all at once. If you want any of those numbers, feel free to ask.
Dan
Island Dweller
Iirc with an 06 he will need 20mm head gaskets. Might want to check.
sent from my Samsung S4
Discussion Starter #15
It was built July 2005 so that should be 18mm...I see your in Navarre, I lived in Shalimar when i was in EOD School!
Island Dweller
Cool, thank you for your service!
APR Head Studs: 250-4202 - stealth automotive $439
OEM Oil Cooler Rebuild kit: 3C3Z 6A642 CA- Order from sunrisefordparts.com $269 shipped
BPD Remote Oil Cooler Kit - Price varies depending on what options you choose.
KEEP IN MIND THAT THE IPR Gen 2 EGR delete is NOT compatible with the BPD oil cooler kit.
IPR Gen 2 EGR delete kit: SKU: EGD-60GEN2B- iprresearch.com $259.99 + shipping
IPR High Flow Coolant Filter: iprresearch.com $249.00 + shipping
2003 Glow Plugs (SHORT) need 8: 3C3Z 12A342 AA - sunrisefordparts.com $13.20 ea. $105.60 total
2004-2007 Glow Plugs (LONG) need 8: 4C3Z 12A342 AA - sunrisefordparts.com $11.27 ea. $90.16 total
2003 - 2004
Glowplug buss bar right side: 3C3Z 12A690 BA - sunrisefordparts.com $40.80
Glowplug buss bar left side: 3C3Z 12A690 AA - sunrisefordparts.com $40.80
2004.5 - 2007
Glowplug harness left side: 4C2Z 12A690 BA- sunrisefordparts.com $40.80
Glowplug harness right side: 4C2Z 12A690 AB- sunrisefordparts.com $40.80
Updated Turbo drain tube: 6C3Z 9T515 A - sunrisefordparts.com $24.37
Updated Turbo Oil feed: 3C3Z 9T516 A - sunrisefordparts.com $87.50
Thermostat: 4C4Z 8575 AA - sunrisefordparts.com $28.60
6.4 Banjo bolts: w302472 Need 2 - sunrisefordparts.com $10.50
6.4 banjo bolt washers: w303659 need 4 - sunrisefordparts.com $3.60
Main drive belt: jk8 1331 a - sunrisefordparts.com $49.82
Secondary drive belt: jk6 664 a - sunrisefordparts.com $25.34
Updated dummy plugs: w302908 - sunrisefordparts.com $24.60
18mm OEM Head Gaskets: 3C3Z 6051 CB need 2 - sunrisefordparts.com $147.60 each, $295.20 total for both. Comes with new updated standpipe, new gasket and head locating dowels (each gasket has one of each and 10 TTY bolts).
20mm OEM Head gaskets: 6C3Z 6051 AA need 2 - sunrisefordparts.com $271.20, Comes with new updated standpipe, gasket TTY headbolts and head locating dowels. Sunrisefordparts.com*
DEPENDING on the MY of your truck you will either have 18mm or 20mm heads.
Build date before Jan 17, 2006 you have an uncommonized engine with 18mm heads and dowels.
Build date after Jan 17, 2006 you have a commonized engine with 20mm heads and dowels.
Water separator updated drain kit: 6e7z 9c082 a - sunrisefordparts.com $12.50
OEM Oil Filter: FL 2016 - sunrisefordparts.com $19.50
OEM OIL FILTER NOT NECESSARY IF YOU BUY THE BPD OIL COOLER KIT.
OEM Fuel Filter Kit: 3c3z 9n184 cb - sunrisefordparts.com $49.95
Exhaust manifold gaskets: 6c3z 9448 a need 2 - sunrisefordparts.com $21.22
CAC boots both hot and cold side. RIFFRAFFDIESEL.com I paid $140 shipped. If your cold side CAC (intercooler tube) is black plastic than upgrade to the metal one. 6c3z 6c640 aa sunrisefordparts.com $115.08
Injector o-ring kit: 3C3Z 9229 AA need 8 - sunrisefordparts.com $31.68 (if you send injectors to Jesse Warren you don’t need this part)*
Fleetgaurd Restore and Fleetgaurd Restore + cooling system chemical flushes. Can get at local big rig truck dealers (they can order it) usually around $23-$30 a gallon, need one gallon of each.
Zerex EC-1 Rated ELC fully formulated coolant, 1 case* buy it at NAPA Part number is ZXED-1 usually between $13-$20 a gallon times 6 in a case.
Rotella T6 full synthetic oil
I would also suggest updated ported rockers OR at the very least new plastic fulcrums for them.
For the rockers here is the Part numbers and prices.
Combination need 6 of these, 4C3Z 6564 AA - $52.80 each $316.80 total for all 6 @ sunrisefordparts.com
Single Intake rocker need 2 of these, 3C3Z 6564 BA - $44.40 each $88.80 total for both @ sunrisefordparts.com
Single Exhaust rocker need 2 of these, 3C3Z 6564 AB - $44.40 each $88.80 total for both @ sunrisefordparts.com
I would suggest push rods since it’s apart. 8c3z 6565 b need 16- sunrisefordparts.com $64.80
Depending on mileage it may be a good idea to replace the Roller Lifters.
Roller lifters with plastic guide and 4 lifters, need 4 of these sets: 8C3Z 6C329 A - sunrisefordparts.com $52.80 a set, $211.20 total
ARP Ultra Torque Lube 10oz bottle with brush*
ARP 100-9910 Ultra Torque Assembly Lubricant - 10 oz. Brush Top Container : Amazon.com : Automotive ARP 100-9910 Ultra Torque Assembly Lubricant - 10 oz. Brush Top Container : Amazon.com : Automotive
Fumoto quick drain valve for the oil pan F-111n
Fumoto F-111N Engine Oil Drain Valve : Amazon.com : Automotive Fumoto F-111N Engine Oil Drain Valve : Amazon.com : Automotive
Fumoto quick drain valves for the block plugs F-108N*
Fumoto F-108N Engine Oil Drain Valve : Amazon.com : Automotive Fumoto F-108N Engine Oil Drain Valve : Amazon.com : Automotive
Snap-on torque adapter tool for rear head bolt on driver side. SRD35 $55 + shipping
11/16 12pt 1/2” drive short socket for head stud nuts.
18mm 1/2” drive 6pt socket to remove head bolts.
Blue spring fuel pressure update: 3C3Z 9T517 AG - sunrisefordparts.com $57.60
Updated STC fitting for 2005-2007 trucks: 4C3Z 9B246 F $42 at sunrisefordparts.com
From Tuscany's thread.
call sinister diesel in roseville ca and XDP diesel they give a military discount on their 6.0 "solution kits"....
I went with sinister since im at Travis afb near sacramento ca but xdp diesel has great prices and loves military!
glad to see another brother running a stroker!
dont forget hpop fitting that tend to wear out.
04 and under- stand pipes blank and dummy plugs
05 and up stc fitting, stand pipes.
get a comeplete gasket kit and get your manifold hot tanked you'll be amazed at it.
Discussion Starter #20
I have already done most of the updates, STC, Dummys, Stands, Blue spring, Drain tube, New oil cooler. All within the last 6 months. I will check with xdp and sinister (most parts on my truck came from sinister).
1 - 20 of 26 Posts
