i need a clutch for a 99 f-350 truck has 7.3, 6 speed manual.. With a small chip NOT EXTREME
We use the truck HARD in the winter feeding cattle.. it pulls heavy loads.. through snow mudd.. we are "on" it all the time starting stopping, backing, gettin hay etc. What do you recomend???
what else should i replace when pulling clutch??
Not sure if the late model 7.3 still has the dual mass flywheel but I would scrap that and upgrade to a solid flywheel kit.
Sent from AutoGuide.com App
i put a clutch in a guys truck EXACT same type of use as you. it was a 99 350 6spd 4x4 dually. hes a farmer and does the same type of thing and then some with his. installed a South Bend 350hp kit which includes flywheel. he is pretty satisfied with it
I put a valiar 500hp clutch in mine. I have a small chip in mine and I mainly use the truck for heavy towing. I have had it installed for 2+ years and haven't had a problem.
