Anyone ever had a problem with serpentine belt skipping grooves and rubbing into motor, alternator, tension pulley, or AC wiring?
I bought the truck about a month ago. It had a descent belt on it but looked a little worn and skinnier than it should. I put a new belt on w/ same part # as old, but it wa much thicker. After a couple days, noticed that the belt was rubbing parts and had skipped a couple grooves in the pulleys. It kept getting worse, so i switched old belt back in and it is fine. Any suggestions?:burnout this is random, but I love this little smiley guy with the smoke. I thought it was stacks belchin out smoke and soot, not a burnout!
