1 - 15 of 15 Posts
Looking for people's real world numbers and their setups
Before city 13.2 / hwy 18
Setup same as sig minus ficm and ficm tuner
After city 15 / hwy unknown unloaded... Setup is the signature but running atlas 40 towing
Currently making a 600 miles trip with a 20 ft boat and about 600 lbs in bed estimated weight is 4500 lbs towing will update these hwy towing miles tomorrow when I fill up.
Mileage is real world hand calculated.. Low my ficm tuner
Reactions: Heavy_GD
I was getting 20 mpg going 70 mph. Before ok atlas 40. Now in getting 18 if I'm lucky. Matt's SRL tune. 3.73 rear end. 285 tires. I'm getti g ready to make some more moves. And I'm thinking MPGs will go down more. Oh well. I bought my TDI Jetta to worry about mileage and diesel prices. 50 MPGs is pretty cool
Tow
Completed the trip averaged 16mpg hwy with boat and bed weight doing 60-65mph.
Gearing: 3.73
Strat: vcxfa9? Whatever the most recent Strat is is what I'm running.
Tires: prolly killin my mpg, 325/65r18 aggressive tread! I'd love to see what my 275/70r18 dura grapplers woulda got.
EGT's never went above 1150 and there are some steep grades in ct and mass.
Running the Atlas 40 has given me quite a bump in MPGs. I'd say a solid 1-2 throughout all my driving. As it sits my daily driving can get me around 320+ miles with half tank left on a 38 gal tank. Just went 477+ with 1/4 tank left.
6" lift on 35's on 3.73 gears CC LB modded up a tad...need to check the weight.
Gearing: 3.73
That is impressive, especially around here with the traffic.
I still have the 4 strat, need to look into 9.
i just flashed a friends 05 cc 4x4 dually with atlas 80hp, he got 20mpg on a trip from mass to delaware last weekend using innovatives extreme race tune, his previous best on this same trip was 15mpg! his truck was ARZ2AL01 which is the original inductive heat ficm cal. i do power hungry ecm/tcm & ficm tuning in house at my shop.
Reactions: Dylpickles
Recently fixed a broken 2004 truck and got f'ing terrible mpg and I'd like to fix it. I cant live with 13.5 mpg pure hwy 70-80 mph. Not towing anything, right?
Engine details
egr delete with up-pipe
head studs with new heads and gaskets.
new filters all around
original injectors with 100k
running opti-lube
Atlas 80 ficm tune
4" straight pipe
4" lift on 33" AT's
What gives?
Engine details
running opti-lube
Atlas 80 ficm tune
4" straight pipe
4" lift on 33" AT's
What gives?
Between 80-70 mph you should be around 11-12 psi give or take not ideal for fuel saving. Keep the truck at 65-70 around 5psi and under and you'll see a huge difference in mpg I promise. I'm currently avg 16.7 in mixed city/atlanta hwy traffic.
The proof is in the pudding lol
Administrator
13.5 is not terrible IMO
I had to use the PHP FICM tune to get out of the 11.s unloaded
funny thing was loaded MPG was about the same lol
now I am at 13.++
Ficm tuning definitely gave me 1-2 mpg bump, ecm tuning didn't help probably because I can't help but put my foot into it every once and a while.
1 - 15 of 15 Posts
