Well my engine needed to be replaced. Well I been busy doing the engine swap let me tell you it has been a long process. But tonight I finally thought I would get to hear ol blue come back to life. Well I go to start her up. I get a high pitch whine. Knowing the sound I am hearing it is the starter but it is not spinning the flywheel to turn the engine over.
I quickly remove the inspection plate cover that covers up the fly wheel and torque converter. I have a friend turn the key and I watch the start engage but not touch the flywheel. The starter does not look worn down and the fly wheel was installed properly. It is the fly wheel off the original engine. It was installed and bolts torqued properly. Everything went together properly. But I can not figure out why the starter will not turn the engine over.
It is like it is too short.
