I have a 2005 F250 powerstroke with a 195,000 miles and the truck will go dead in three days. I have replaced the batteries twice and still have the problem. in each battery I have 14.5 volts. I cleaned all the connections to the ground and power side of both batteries but it still goes dead in three days. I have 9.5 volts going to the ground. All the conponents work except the hood light when raised. I have to put the battery charger on it everynight. I have checked the altinator which I replaced two years ago I pulled the ground off while it is running and continues to run which tells me the altinator is good. I dont know what the problem could be? Could this be the GEM Module? I have checked everything else I can think of. If anyone has any suggestions or help would be greatly appreciated. Thank You Bill
