My Build has been Quite a journey.. I don't claim to be a 6.0 guru by no means but seems like once you tinker, you will have no choice but to learn quickly.
I pull a 17k 5th during the summer and this was the whole reason that I started to up grade my truck... heavily.
I started with a turbo from a different vender.. that claimed this turbo was the answer to all my problems.. well that turbo... absolutely sucked... no other way to put it.... so here came the new and improved... well not only did this turbo suck but it grenaded with about 2k miles on it... 4 months later a smaller version finally showed up and 30 minutes into my maiden voyage it started blowing grey smoke.... So I sent that one back and luckily got a refund..
Then there was talk about James @ Barder Turbo Services. A few people I trust off the org had been running them and reported excellent results. so I bought in.
The stg 2 with stock injection was a great improvement. The tuners are able to give you just what you want/ need with that combo. I was very impressed. With my heavy tow file, this combo worked well but seemed right on the verge of needing more fuel.. I had been told turbo number one would pair nicely with 175cc injection and would be capable of towing.. so I had my sight on 175/30 ever since last august.. A Big THANKS to ODawg , 1fasttrx and Fox Hunt.. and Barder Turbo Services!!!
I was discussing my Barder stg 2 with Tuscany and he mentioned injectors from Warrens Diesel.. After telling Bry my fears of upgrading injectors.. he worked some magic and I received 9 injectors from Jese.. Now I have a spare for insurance.. as going down with my trailer behind me would be an absolute night mare and the wait for a replacement would kill me.. Now, I might have to pay a shop bill but I have the parts in hand if the rare chance I have and injection failure..... Big Thanks to Tuscany and to Warrens Diesel
I finally buttoned my rig up today and went for a rip.. first with stock tuning.. Holy crap it ran good. No smoke, No lag and as much power as my tow file with stock sticks. I ran for a bit and then loaded a mild srlx tune from GearHead. Man this file is running great. There is sill some air in the rails and ecm is still learning but every thing seems spot on.. Smoke is very minimal unless you stab it but it is not as bad as my stock charger, stock sticks and Looney Wild.. This tune should be capable of towing 8k and I believe it can.. Temp would touch 1200 deg on an all out run and I would run out of road with every try. On the Interstate, the truck goes from 60 to 85.... NOW!! and this is with a tow capable file. This combination is VERY fun and extremely streetable!! I will run this for a while to see if any tweaks need to be made...As soon as snow flies I will be pulling my 3 place enclosed trailer.. about 6k and see how it does..
I have 3 tunes from both.. GearHead and TSD.. Both of which responded in an excellent time frame and seem readily available for questions and Tweaks...
A big THANKS to Matt and Chris!!!
