1 - 5 of 5 Posts
Got the FP out without removing the turbo. Stabbed the new one in. Can`t get the banjo threads started. Any tips or tricks?
When you install it I went backwards a few turns and felt when the threads bumped in and lined up. That way you are at the starting point and you do not have to go round and round trying to find the start. Alot of people talk about having to remove the pedistal but I thought there was quite a bit of room. Esp. after working on heavy equipment for a living.
Infidel
Yeah, what he said. Make sure that the brass "washer" is in place as well or you'll leak fuel. Time and patience are also helpful.
Keep us posted,
Craig
try starting the bajo bolt a few threads before tightening down the two side bolts. did mine like that after reading the install thread for lift pump
Thanks, I`ll try that this morning.
1 - 5 of 5 Posts
