I was on my way home from work yesterday and got about 500ft from the house, pushed the brakes and heard a clunk and the front end shook pretty good. Not enough to throw it in the ditch, but like running over a possum. I checked all the driveline, suspension, and steering and everything was tight. the ball joints are the only thing I haven't checked and the symptoms sound like ball joints.
The question is, do you check these like all others, jack the front up and pull up and out on the wheel and if there is any movement, they are shot. If they are, I will do both sides. I have heard about taking the hub loose to do this, can the hub just be supported while the joints are swapped out?
Thanks in advance
Thanks in advance
