1 - 5 of 5 Posts
I have a 2002 F350 with around 102k miles. It has a rough idle @ start-up after sitting overnight. It will clear itself up after driving for about 2 miles OR plugging the block heater in overnight. I thought with the plugging it in solving the problem, glow plugs may be the problem. I had it looked at today and was told the glow plugs are all good and the problem is likely the injector (s) but have to run a test to see which injectors are bad. Would the injector problem go away with plugging the block heater in ?
Hey,
I had 1 injector go bad on my truck 2000 7.3 and for a while it would idle rough when cold, didn't think much about it. then on my way to work it just stop running. took a while for me to figure out what was wrong, but finally I took it into the dealer and I had one injector bad #4, witch dropped the oil pressure in the high pressure oil lines enough to stop all the other injectors from working.
Injectors can cause white smoke on start up if they are wore, ill bet you have a couple contribution codes!
I've had white smoke a couple times on cold start-up but not regularly. If the injector(s) end up being the problem, would plugging the block heater in "mask" the problem because I never have a problem if the truck is plugged on or throughout the day - just on initial morning start-up after sitting overnight.
Yes, it warms up the oil, and the cylinder is not as cold, so it burns easier, and better.
1 - 5 of 5 Posts
