1 - 20 of 28 Posts
· Registered
So last weekend, my vacuum pump started running constantly, sometimes while riding along I can hear some god awful noise from the "driver side wheel area".
I have the manual lock hubs and the "circular"swith to go from 2WD 4HI and 4LOW, is that ESOF or do I have to get out and manually lock to put into 4WD?
Second, can I fix just the vacuum leak or have to change the whole $400 hub assembly?
Thanks!! :dunno:
· Registered
Discussion Starter · #2 ·
:bump:
:doh:
· Premium Member
If the pump is running, there is something screwy somewhere. The pump should only run when the switch is moved to a 4 wheel drive position.
Yes, that is the ESOF system on your truck. (Electronic Shift On the Fly)
When you flip the switch, the vac pump should come on and the selector on the hub should move to the "lock" position. I don't think it is a constant vac, but pulsed..IIRC
The knuckle is sealed (2 seals, one on the axle, the other is on the bearing). Theres a rubber vac line on a nipple on the inside of the knuckle.
· Registered
there is no way that little pump is moving those manual hubs..... i need pliers to move it manually
· Premium Member
You should remove them. Three torx 27 bolts hold them in. Once those are removed, tap around the outside of the hub with your fist until they pop out a little. You can use a thin reg screwdriver to gently coax them out.
Clean them up, look for metal shavings and needle bearings inside the hub on the truck. If you see that, you need new hubs (I did this this past weekend and found all kinds of scary things). If you get nothing but grease out, thank the Powerstroke gods for smiling upon you and grease the heck out of the hubs before re-installing them. I packed it much like a wheel bearing back in the "old" days.
· Registered
I'll check it out this weekend, thanks
· Registered
the hubs are pulse. There's a plastic disc near your hub that the vaccuum pump sends a pulse of air to rotate. If you have this then you have the hubs that are "auto-lock" instead of "lock-free". It doesn't actually turn the manual lockers, just the disc behind the hub that actuates the gears inside. If you're having a problem with the pump running, chances are its just the pump, not your hub. I'd say disconnect it for a short time and drive to see if you're getting "resistance" from that side. You don't actually need to have the pump hooked up for your 4wd to work, you'll just have to climb out of your truck with some vice grips to get it to lock. But if you're looking to replace the pump, junkyards around me sell them from 50-75 so its not horrible.
· Registered
Discussion Starter · #8 ·
I can hear the drivers side when riding around, like a really fast pulse then i can feel it kind of hit the spot, but im not in 4WD???
· Premium Member
Sounds as though you might be having a u-joint problem (the one on the axle).
Does feel like it grabs?
Sometimes pulls to one side, then if you fight it, it may pull a little in the other direction?
When you are going straight down the road, it can almost fell like the front of the truck "floats from side to side."
Any of that sound familiar?
Also, have you had any work done to the front end recently?
· Registered
Discussion Starter · #10 ·
Im not getting any pulling, the truck had new tie rod ends in January and an alignment. The mechanic said everything else looked pretty good underneath (doesn't mean they can't go bad) the shop is reputable for our bigger trucks because the other shops can't put em a lift hence they get all the local areas work.
The part that I feel doesnt seem like something heavy duty, more so something smaller finding its place and this all happened the same day, vacuum constantly running, and the npise from the hub and A/C only from the defrost.
When riding and I hear the noise start, if I hit a bump and stops, shortly thereafter it starts again till it finds its place but I need to be on smooth ground for a bit.
· Registered
ouch, now that you say it happens when ya hit bumps and smooths out at another bump, definitely sounds like a bad hub. Had that happen to me before and a week later my passenger side seized up sending me into a ditch on I-90 near buffalo ny. I'd say ya better get it looked at, take the hub off, if its shot, usually the needle bearings fall out soon as ya free the disc from it. And as far as price, I got a set off ebay for $160 plus shipping ($20-25 I can't remember) They work great, fit good except for the wheel studs, I just removed them and used my old ones, thread was off was all.
· Registered
I have ujoints failing on my 06. Thought it was hubs at first. After digging found the bad joints.
If you have to replace your hubs, be careful. Ford changed them after 04. I could not find any aftermarket replacements. Not even Warn. So be very sure its hubs before buying new. 600 a set from the dealer.
Good luck
· Registered
Now arent there really technically 2 hubs per wheel. The wheel hub, which is around 300-400 and then auto locking part of the hub? What would be the service interval/suggestion for the hubs? My 4 wheel wont engage by vacuum either.
· Registered
yep...there's the Wheel Hub Assembly which is your wheel bearing and the expensive part and your locking hub. Luckily you don't usually have to replace both at the same time as long as it doesn't all seize up on you. I'm not sure there's really a set "maintenance" interval. Unfortunately I have a hub assembly blow out on me about every other year, but on a plus side I'm the only person I know with that bad luck.
· Registered
Another symptom. Going straight down the highway 70 mph the truck would suddenly with no warning at all go right. it would jump a half a lane before I could catch it. Any suggestions?
· Premium Member
:dunno: Slow down and don't drive beside anyone??? :dunno:
In all seriousness, that sounds VERY different than the typical "death wobble" or wandering that you hear so much of. I don't have a clue, beyond checking the tierods and the drag link.
· Registered
really sounds like the hub is going/gone on you. The needle bearings are probally scattered everywhere inside at odd angles and binding on you.
· Registered
Discussion Starter · #19 ·
So not the cheaper part(manual Locker), the $400 bearing assembly? This truck has been a money pit, literally as soon as I fix something, something else breaks almost instantly.
· Premium Member
No, I am pretty sure he is referring to the part where you can manually lock the hub. That is the $600 part.
1 - 20 of 28 Posts
