I been noticing that my truck takes longer to start than usual if the outside temp is around 75 - 80 degrees she fires up without a problem. Anything below 70 degrees you will have to lay on the starter for about 10 seconds tops till she fires up. I did notice a slight white haze come out of the tailpipe. Trying to figure out if its the glow plugs any input would be greatly appreciated.
