1 - 20 of 25 Posts
I'm a new Ford owner. 2011 Crew cab w/short bed. Factory radio/ CD no sync or Nav. Considering my options to add Sirius and a backup camera. I'm not familiar with the rear camera factory setup. Where is the camera mounted? Are the wires in the harness to add the camera (in dash and at tailgate?)
Any advice? Thanks.
(my last truck was an 02 1/2 ton Avalanche. What a difference with the Ford. WOW. Should have gotten the Ford sooner. Glad I did it)
So you don't have a factory camera? if you don't you would have to buy the rear view mirror which has the screen and the camera. I am pretty sure all trucks are prewired for it. I bet the cheapest way would be to get a aftermarket nav with sirius and add a camera to that.
I am thinking about adding a Kenwood rcvr that does sat. and video. What I don't know is if I can simply plug in the stock rear camera (is there a connector and is it pre wired into the harness) on a truck that doesn't have a camera. If so, where do you pick up the camera feed in the cab? In dash (for stock Nav unit) or headliner (for mirror display) In an ideal world...I would simply add the factory camera to the tailgate and wire it up to the new head unit using the stock wire harness.
Any thoughts? Anyone tried this?
I don't know of an adaptor. I think if you want it to be "like" factory, you will have to play mad scientist and pin it out. If you have none of the above, just buy you a license plate camera and a double din screen.
My wiring was not there for 2011 f250 xlt. You will need to get the head liner wire that comes from the mirror to the passenger side, this will be plug and play. Then if you dont have the wire that comes from the rear of the truck, then youll need to run the video +/- and shield from the camera (I made my own aluminum tape, stripped wire and 2-18 guage wires for the +/-). Plugged my power to the camera at the reverse wire and grounded it on my trailer ground wire. I bought my OEM mirror and camera from NAILSandsales on ebay for 300$ . I used a 2011 f150 mirror and the camera mount, worked perfect.
The camera is located on the tailgate handle. The harness runs through the tailgate and up to the cab. You'll most likely have to purchase or fabricate a harness as its doubtful your truck is prewired. While you can certainly add a rear view mirror that is compatible, you'd like the camera much better if it came up on a nav unit or larger display like that. Good luck, let us know how it goes.
Thanks for the advice. I probably won't tackle the stereo/camera project until summer. New project jumped to top of list. Bought a used Leer cap on Craigslist for $350. Matches good. Paint is spot on match. Got a few scratches that need to be compounded out. There is one issue. Rear window doesn't close completely because of newer style tailgate. I have to either replace or modify the window. Still - at $350 for the cap it's a great bargain.
No kidding, I'm right there with you on the cap. Torn between Leer and ARE. Sadly, I can't get what i want with ARE so I'm having to go Leer and my local Leer dealer sux.
Either way, $2000+. You got a heck of a deal for $350. Congrats.
Thanks for the feedback. Good luck on finding a cap. Oh, my Leer dealer has yet to quote my replacement window. Dunno if Leer or the dealer is the problem. Still waiting....
OEM mirror/monitor
I have a 2012 F-250 Lariat Powerstroke and finally dumped my 04 6.0L HD F-250. So far I'm pleased but now want to add a few bells and whistles that didn't come with my truck. I want to hook up a back up camera and mirror/monitor. It now has a back up alarm and a auto tint rearview mirror with a 16 point plug/harness. I have access to a factory OEM rearview mirror/monitor and want to know if this will work with my existing harness and how would the camera hook up to it? I called my local dealer/parts guy and he said not much info in the books with wiring diagrams but for my model a camera harness is available for $30. Books doesn't say if you can add this system. Oem mirror/ moniter is around $1,200! For that kind of money I'll just keep walking back to see how close the trailer hitch is.
Since I have a 16 point plug now and it matches the new OEM mirror/monitor should'nt this all be a plug and play system?
Any help or advise on this? :dunno:
Not sure how to do it, but try to find SRedmyer on this forum. He is the guru of camera systems on our trucks. If anyone can help, it would be Steve. Good Luck.
Hey Steve,
Do you have any updated status on the 4D for the '11 & 12 with factory nav yet? :please:
My anniversery is comming soon and the wife needs to buy me one :D
Hey Steve,
Getting close...with the help of a member of another forum I have a fornt camera solution. Now just need to get the buttons figured out.
Steve
If i end up getting a new truck id like to know this as well. I will be checking bach here and see what you figured out. I think id just add the rearview mirror one. Looks like it would be cheaper then a nav unit as well
I too am looking at a 250 right now and am anxious for this info, as it has the same scenario. Look forward to a quick response. Also, new to the forum...hi everyone!!
I have a 2012 F-250 with the factory backup camera in the rearview mirror. I am adding an aftermarket nav unit and would like to tap into the camera signal and either split or move it to the nav screen. I would prefer not to drop the headliner. Does anyone have the wiring information for where I can tap into the camera signal under the dash? Same for the factory Sync microphone. I am ditching Sync and would like to use the factory microphone instead of installing the aftermarket one. I know that the factory mic runs the the Sync module behind the right kick panel but don't know the pin locations. Any help with locating the camera and microphone wiring would be greatly appreciated. Thanks!
I have a 2011 F-250 Lariat with a back up camera that goes to the rear view mirror. It came with a CD/XM basic radio. I just installed the Sync1 Nav radio which is very nice. Everything works but have not been able to connect the camera from the rear view mirror to the Sync1 Nav radio - I purchased the hardness from infotainment that plugs to the back of the radio and has an RCA video cable but have been unable to find where to connect. The wire to the rear view mirror is routed through the passenger pillar. Any idea of how to get find that wire?
Thanks,
1 - 20 of 25 Posts
