1 - 2 of 2 Posts
Hello, I have been doing an 2005 dash swap into my 2001 7.3. I discovered that the "stubby" column shifter doesn't have a light on it anymore. Rather they have an indicator on the instrument cluster. Hooking up the new switch I have an extra green/white wire on the 7.3 side that I am pretty sure is the ground for the light in the old O/D switch. Does anyone know if I can use this to set up a button light to use as an indicator for when the truck is in overdrive?
Also, any questions about the swap are welcome! I kept the OEM instrument cluster, but the rest of the dash is operational minus a few features I dont have like the power pedal adjust, or power rear window.
Hello and welcome to the ORG. If I may ask, why would you want to know when the truck is IN O/D or O/D is on? The factory setup only illuminated the light in the shift lever when O/D was off. Just curious.
1 - 2 of 2 Posts
