I bought my 99 f250 about 2 years ago. When I bought it, it was shifting messed up. It will take off in 1st gear, and not shift to 2nd gear, about 70 percent of the time, unless I lift my foot off the throttle,it will go into 2nd, then it would go into 3rd, then skip 4th and go into overdrive. If I accelerate, more then half throttle, before it goes into overdrive, it will go into 4th for abouut 2 seconds, then shift to overdrive quickly. I ran a scanner and it gave me a code for the shift solenoid. I put a brand new solenoid in the tranny, and it still did the same thing. I ended up getting the transmission rebuit with a new torque converter, new filterand new fluid about 15 months ago and it still had the same problem. Ive been driving it like this for awhile know. Now here is the weird part. I was driving the truck most of the day today, and about the last hour of my driving, I decided to turn off the overdrive. It still shifted the same way for 10 minutes, and then I took off from a dead stop, and it went through the gears perfect. Better then ever. It ended up shifting perfect every time until I got home. 10 minutes into it shifting perfect, I noticed the overdrive light flashing. When I got home I hooked up the scanner, and it gave me codes, p0781 and p0732. It told me what the codes are, but what is making it have this problem. Please help ASAP. 2 years of this is enough. Thanks for the help.
Sorry for the long post.
