Who here has a chance to use this, i got mine in and was using it on my truck but im not really sure how to use it or understand the data i get. I dont have any trouble with the DTC but when go to use the onboard system tests i dont know how to read data
BUMP I,m interested in know more about this too
i have it. it works really well.
not really sure what you are asking, but if you go to live date meter you can select anything you want and monitor it. record, whatever.
if you go to test onboard system you can run some test there. and then if you go to onboard test results it will show you how everything you tested is working
ya i go that figured out, is there a place on there where i can read my HPOP or ICP senor?
