1 - 9 of 9 Posts
<-Day Of Fail now SOLD
Since all the off road diesel threads have been showing up someone mentioned something about ATF leaving the same dye color as offroad diesel. I mentioned to my friend that has been running used ATF he started freaking out:rofl: will it show that same dye color as off road diesel:dunno: Or will fade when reqular #2 is added:dunno:
Discussion Starter #2
Lots of looks but no thoughts?? Maybe a :bump: might help.
Tell your buddy not to worry, I ran heating oil all winter before realizing it's not worth the fine on the little bit your saving each tank. Run a few tanks of road fuel (clear) and change filters if u want to be safe, but ? is why ATF? I'd rather throw a quart of 2 stroke in there for lubricity which is formulated to burn. Good Luck:thumb:
ATF if supposed to clean injectors....
Probably so being as it is formulated to do just that (clean injectors)
The Diesel in Az is Green. It would take alot of ATF to change it to red.
I think it would have a pink hue to it but I doubt it would look like red dye at all. Red dye looks like Kool-Aid but if you got green and red and mixed it then it would make ???
I ran off road for a while, when I switched back to the green fuel, after two tanks, I still had a little red color in my fuel filter bowl.
1 - 9 of 9 Posts
