Alright so here is a rundown of what I know on the truck and how I came upon it. This truck a little less than a year ago came up for sale on Facebook market place. $3,500.1995 Cclb dually 5-speed. It has 219,xxx miles. The truck had a lot done to it and from my understanding it was very recent to what is happening now.
the truck has as follows
-17 degreee hpop swash plate
- full force 180/30 injectors
-php hydra tuner with custom dusty holgate tunes
-avp 9 blade compressor wheel
-New fuel system 48 gallon rear tank 18 gallon front tank
- 444 fab regulated return electric fuel pumps
-3” downpipe to a 4” straight pipe
-new radiator (degas bottle was not hooked back up)
-new uvch on both sides
-new glow plugs from ford
-new icp (unknown brand)
-new ipr (unknown brand)
The original add said it needed and oil cooler. Not sure how the guy came to that conclusion
A buddy of mine bought the truck planning to fix it. He has had it about 6 months and hasn’t touched it and wants to sell it because he found something else he wants more.
I love these trucks and this seems like it could be a good one. I talked to him and brought the truck to my house so I could try to do some diagnostics on it.
First thing I noticed was when I started it 60mph degrees outside there was no smoke, the engine was a lot louder than most 7.3 power strikes I’ve heard (sounded kinda like a knock on the top end) but it ran good. Drive the truck about 2 miles to my house and it was smoking white. That matches up with what he told me that it only smokes when hot.
About and hour after I got home I went back out to check fluid levels. Coolant was low, oil level seemed good and just smelled like oil (had slight brownness but I figured it was from it not being properly warmed up, buddy would start it and not let it fully warm up a couple times a month). I topped off the coolant (took almost 4 gallons and changed the oil. All the oil that came out was brownish but not really milkshake like.
Started the truck and it was just bubbling the coolant out the rad cap hole (cap was off) but ran good. After about 5 min it started to smoke. I started to unplug the harness to the valve cover to see if it would lesson the smoke. Didn’t change the smoke but made the truck run a lot worse. Went to do the driver side so I removed the air intake so I could get to the rear plug. Started the truck and milky sludge started coming out the ccv. I left it at that for the night as it was dark and getting cold.
next morning (22degrees outside) i went out and pulled the rad cap and could not see the coolant again. I put about another gallon in leaving it about 1/2” from the top of the rad. Pulled the dipstick and there was white foamy **** in the did tick tube but the oil on the dipstick looked good for the most part(had some of that foamy stuff on it) oil level was still good didn’t gain anything it seems. Later that day I got some hotshot stiction eleminator to put in the oil and some hotshot diesel extreme for the fuel, and fuel filters. Started the truck and it was smoking some but not terrible (it was cold and I didn’t plug it in) the smoke never cleared fully. It got better for a little and then came back strong again. I let the truck warm up to the bottom of the normal zone on the dash and put the rad cap on. About 10 seconds later it was really smoking and it smelled sweet. Ran it like that for about 2 min on high idle 1,100rpm. I slowly released the pressure on the cooling system. I saw a few drops of what maybe looked like oil or fuel possibly. I then went inside for 5 hours and didn’t touch it. In that time it lost enough coolant to just barely cover the fins in the radiator, oil still looks good and I don’t see any visual leaks outside the truck.
what could this be? Cracked injector cups, head gasket, cavitation, cracked head,?? Not real sure what direction to head. Another friend of mine thinks a headgasket is probably shot
