1 - 10 of 10 Posts
Is the ARP assembly lube just white lithium grease? Basic engine assembly grease?
ARP claims it is "special" lube to ensure correct torque... Not sure I would use anything else as its a pretty critical torque process.
ok so I guess that answers that. So how much is needed for a single head job?
Maybe I should ask the question in a diffrent way,,I have read in other post's that the small tube that comes in the kit is not enought to do the job. What do u think?
IMO you should order an extra tube, that little tube is little lol. It will barley get the first 5 studs if you lube them up correctly
Administrator
That is dumb .. they brag about including the lube for free so you can do the install per spec .. then they don't give you enough ?
first I heard about that , Hope My dealer got it situated properly
I agree,first off $450 + for a box of bolts? Whats the profit margin on that? And then short change the broke bazztard u just soaked?:doh:
Mine should be here monday!:rofl:
1 - 10 of 10 Posts
