1 - 1 of 1 Posts
The clear coat on mine is getting loose in spots. Looks like it's oxidized underneath, collects dust, water, definitely needs to be fixed. Thought I might be able to abrasive blast the clear coat off, then re-clear, not a good idea. :doh: And of course, half the mounting studs break when you remove them.
So, are there replacements available? Any suggestions for different material? Any aftermarket inserts that would fit? These are the only bad spots on the truck, I really need to do something with them.
1 - 1 of 1 Posts
