1 - 7 of 7 Posts
Title says it all. I want to know if the hot and cold pipes from the intercooler will fit an 05. I'm switching to a metal pipe and need to know if the 03 pipes will work.
Thank you
As long as you have the correct intake elbow setup I don't see why it wouldn't.
i have an 05 setup, that is why i asked if it will fit an 05
WWW.COMPIGNTECH.COM
YES it will fit the only differences are: 03's had a metal cold side pipe and the 05's are plastic, 03's had a throttle assembly on the intake elbow 05's don't and if you have dual alternators than the hot side pipe is flattened to clear the second alternator.
Since the 03's had a different intake elbow will that affect anything?
Nope, your good to go.
SOME 03s had a butterfly UNDER the elbow/above the intake. Mine is an early 03 and doesn't have one. The 03/04s that do, it doesn't interfere with the elbow. Unless I am mistaken, it had something to do with the EGR system.
Sent from my LG-VS700 using AutoGuide.Com Free App
1 - 7 of 7 Posts
