What I mean is that when the truck "thinks" there's zero miles till empty, after awhile it will cut power for about two seconds, then be normal for six or seven, then cut out, then normal, etc., until the 'miles to empty' updates to anything above zero. I have a TransferFlow tank in the bed- and it reads the factory gauge, often telling me I have a half a tank yet the truck hasn't updated and I end up with this issue while going down the road. The TransferFlow gauge is accurate- verified by how much I can pump in the factory tank. Just the truck's cluster doesn't update near quick enough on some long hauls.
Is there any way to either disable this "hey dummy you're about to run out of fuel feature" or force the damn thing to update the fuel gauge/miles to empty faster? I can manually pump more fuel in as I'm going down the road, but it's kind of a pain in the *** and not a very fast method with the small pump on the TF tank setup.
I have FORScan and a cable, if there's something I can modify that way. Probably not, I'm sure.
I have 104 gallons total capacity but it's tricky to run it more than half empty on a trip.
Even when I manually pump fuel into main tank, like 25 gallons even, the gauge will eventually read near full, but fifty miles down the road it's back down toward empty probably based on what kind of **** mileage it thinks I'm getting or something.
Thanks for any insight, sorry for the novel!
